Configures all the peers in a peer group to be a route reflector client.
| peer-group-name | Specifies a peer group. |
| route-reflector-client | Specifies that all the neighbors in the peer group be a route reflector client. |
| no-route-reflector-client | Specifies that all the neighbors in the peer group not be a route reflector client. |
N/A.
This command implicitly defines this router to be a route reflector.
This command applies to the current VR or VRF context.
The peer group must be in the same AS of this router.
The following command configures the peer group outer as a route reflector client:
configure bgp peer-group outer route-reflector-client
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
